Low-High Cut gain control
Simple suggestion. Instead of having 3 to 6db increments when adjusting gains on the Low-High Cut EQ, please make it move by increments of 1db. I use this EQ block daily and sometimes 3db makes too much of a difference.
Is this not one of the parameters that can be long pressed and type in a specific value?
Please explain the long pressing feature and I’ll give it a try. It is not something I was aware of.
If you tap on the number for a parameter it will pop up a numerical keypad where you can directly enter in the value.
The issue for the parameter value tap on the ‘Low-High Cut’ block is that it does not work (bring up the numerical keypad) on the ‘HPF SLOPE’ and ‘LPF SLOPE’ parameters. At least not for me. I think at least for now, barring this being a bug, you are required to select from the slopes they allow via turning the knob.
Should mention that I think the selection of slopes is still vastly more flexible than the slopes available on similar EQ blocks on some other modelers.
This did not work for the HPF Slope and LPF Slope, like HonestOpinion said. And these are the parameters I want to have less of a drastic climb from.
Thanks for the clarification!
