Single block for FX loop integration of a external pedal
Sometimes I just want a single pedal to be in a certain place in the chain, at the moment I have to waste two blocks for a simple signal routing action thats not taking up any processing power and its quite the job doing it in an already made preset at the moment.
Just made an optional FX1/ FX2 block and its simply using send/return of the FX I/O.
I don’t get this - don’t you just patch your pedal into send1/return1 or send2/return2 and then add FX Loop 1 or FX Loop 2 to your preset???
There is already a single FX(1/2) block on the device. So topic is redundant.
