My band’s been running a single Quad Cortex for both guitarists — Input 1 → Output 1 (FOH/IEM) + Output 3 (power amp/2x12 cab), and Input 2 → Output 2 (FOH/IEM) + Output 4 (power amp/2x12 cab).
It’s been rock solid for about a year with no issues, but recently we’ve started noticing something weird — the signal from Input 2 is bleeding into Input 1’s outputs. It doesn’t happen the other way around.
For example, if Input 1 has an octave pedal on and Input 2 doesn’t, you can faintly hear Input 2’s signal with the octave effect through Output 1 (IEM/FOH) and Output 3 (2x12 cab).
Has anyone else run into this? I remember seeing another thread about signal bleed being firmware-related, but I can’t remember which version I’m on. Is there any way to roll back to a specific firmware?
