I’m looking to experiment by micing my Bodhran drum into the QC, then into Reaper. I’m not having any luck getting a signal. Anyone tried anything similar? I use a Cloudlifter with it and made sure it was working within a track in Reaper, which it does.
you are using XLR? Did you switch the input type to Mic on the swipe-down I/O screen of the QC and enable phantom power (if needed)?
Actually I didn’t change the input type, that’s probably it. Yeah I’m using an XLR
Let us know if you’re getting it working… I have an SM7B as well, haven’t bothered trying it with my QC.
Yes it works well, I just had to swipe down on the screen and change the input from line to mic, and also turned on phantom power.
