How to connect the Mic using Quad Cortex
I connect my Mic to the Quad Cortex selecting input and output but the Mic doesn’t sound. Any advice ?
Is your input set to MIC in the drop down I/O settings?
Yes it is with Mic
But it doesn’t sound
On the I/O settings page for the mic input you can check the input meters to see if QC is getting signal from your mic.
If it is, then the mic probably isn’t correctly routed to the output you are listening on. How are you trying to listen to it?
Also, what kind of mic are you using? Does it need phantom power?
We need more details to be able to help. :sweat_smile:
