Hi There, iam just trying to get a Microphone with an XLR Cable to work on my Quad Cortex but i fail.
The XLR inputs dont seem to work, when i use a normal quater inch plug it works fine, but not with the XLR.
The Cable and the Microphone work without problems on my mixer but on the QC there is no sound.
The microphone with a TRS Quater Inch Plug also works with no problem, ist just the XLR cables dont seem to work
Do i have to activate XLR input somewhere in the Menu?
Hi @Rexindigo, yes, you need to change the input from instrument to mic.
If you swipe down from the top of the screen, you have the i/o settings.
Then select your input and switch to mic. And you can activate phantom power if needed.
Thanks that was helpful
i Knew there was something…
