If I download someone else’s tone, can they set it up so that i cannot change the settings within the Scenes? Whenever I apply a new setting to one Scene, eg Scene D, it gets applied to all 8 Scenes. This only happens with downloaded Tones, is that correct? Can a user can set up the Scenes so that it cannot be changed, or if it is changed, then it is changed across all scenes. IS there a good video on Scenes that Neural endorses? Thank you
If there’s a parameter that you want to change between Scenes, you need to long-press on it for about 2 seconds, until an “ABCD” icon appears. From there, you can set what value you want for each Scene.
Otherwise, the QC will treat any parameter changes you make within the preset as across all Scenes.
Thank YOU, that’s awesome, I appreciate it!! ![]()
