Hey everyone, I’m not sure what I’m doing wrong but in a scene I just created I’ll get it saved but when I go back to some of the scene modes like rhythm w/ tremolo, the tremolo will be off even though I saved it with it engaged. If I shift then over the slap delay mode, the tremolo will be engaged, for swells mode I’ll get it set and saved. When I shift away from it and then back to it only some of the effects are on. I save the scene after every change. Any thoughts?
are you enabling scene assignments by right clicking the parameter you want to adjust separately? On the QC itself you long-press the parameter (or bypass button) to enable scene assignments and a small ABCD box appears.
On the editor you must right-click to activate it per scene
I have done that, but it still continues to do it.
might need to report that as a bug then, it’s working correctly for me.
Are you using Hybrid mode with scenes and stomps enabled together?
If so,
Make sure that blocks don’t have stomp assignments on them if you only want them to be controlled by scenes, and/or…
Check your Scene Bypass State Behavior settings.
