Routing question
Hi all! I would like to understand if it’s possible to create a routing like this:
Send 1 → pedal mono in/pedal stereo out → return 1&2
Send 2 → external preamp —> IN 2
This way I can use the extra input 2 and and the “unused” send 2 to create an extra loop for external preamp/pedals, since send1 and return1&2 are already used by the mono in/stereo out pedal…
would this work??
Does IN2 take like level as well?
thank you!
yes, you can do this. I have a preset on the Cloud built as a template for this use.
You can mix the Input 2 back into the grid at almost any point you like, or use the Transparent Blend to bring it back into the signal path.
Settings and levels will depend on the specific pedal or preamp you’re using for the mono-loopback, but physically it’s definitely doable.
