FX loop using output 3 and input 2
Would be great to be able to use output 3 and input 2 as a third mono FX loop when using FX loop 1/2 as a stereo loop. Or is this possible now in some way?
You would have to arrange it so that you send the signal out to Output 3 at the end of a row on the grid, then out to your pedals, then receive the signal back into Input 2 on a different row.
Also, double check the input and output levels of all jacks to make sure they’re where you want them to be.
If you don’t need to FEED full stereo to your looped pedals (just stereo return) you can use Send 2 to connect to Input 2 for a ‘quasi-loop.’ Or ‘pseudo-loop.’ Or whatever that would be.
Just a workaround I’ve used when I don’t need the stereo send, just stereo return
