I am using the TRS output or the XLR output from the DSP into my Apollo x8 audio interface. I have used the Hi-Z inputs and various other inputs but the level into the UA Console app is quite low even with the QC turned up quite a bit. If I go higher than 75% it gets more distortion. The input is really too low to use to record into logic from console. Anyone else have this issue? Any solution?
I discovered you can alter the settings on the inputs and outputs. I am not at the QC and I forget how I accessed the software settings. I believe you Swipe down and the software level I/O will appear. You can make changes there. I also use an Apollo BTW.
Isn’t it possible to just go from the QC straight into the computer and skip the Apollo altogether? I think those are on Channel 7-8, but someone can correct me if I’m wrong.
It’s plenty hot going into my recording interface. Like mentioned above, check the levels in the output screen (swipe down) , as well as the levels on the patch itself
