Hey everyone,
I was wondering if it’s possible on QC to access the tuner with a single quick click on a pedal? This would be the most practical solution for live gigs. Has anyone managed to set this up, or is there a way to do it?
Thanks in advance for your help!
Hi,
in the Settings menu you can swap Tempo and Tuner Function, then a double click opens the Tuner and Holding the Footswitch opens the Tempo Menu.
Greetings from Germany!
Thanx…
Better than waiting for 3 sec…
But still 2 clicks
If you are willing / able, a midi controller can do this. One click on, one click off
You can also use an XP to do that if you use the midi jumper hack
