I have Nameless, Cali, Abasi, and Plini.
Using Abasi I’ve fined tuned the CAB section.
Is there a way to carry this over to the other 3 platforms?
Or, if I use the same settings on say Plini, will the IR signature be the same as Abasi?
I’d like to standardize the CAB sections on all 4.
Thanks!
You might have to use a DAW and just have one instance running the IR section only and you can swap out whichever frontend you want.
