Quad Cortex USB ROUTING
Continuing the discussion from Quad Cortex isn't working as an audio interface:
Important: If you are using your QC as your AI, be sure to select USB 3/4 as your outs on your preset of choice.
Someone needs to do an ’ Everything you need to know about using your QC as your interface’
Cheers
Waal
Not sure why it was necessary to post this. As with all things, RTFM.
‘multi-out’ works fine too.
TY RTFM.
The reason for the post is that the manual doesn’t cover all of the little gray areas that can occur that aren’t as cut and dry.
I thought that I could leave it set to multi, my preset outs, but in my experience, after playing back a very weak signal guitar track, it was cleared up instantly. Once I said it to USB 3/4. I will go back and check and see if maybe it was due to some other routing. What I have noticed initially was that my signal coming into able to live, what is it about -24 to -30, and there was no way for me to raise the signal input into the channel. Again, once I set my outs from multi to USB 3/4, the problem was remedied.
There definitely are areas the manual misses. A user-maintained wiki is in the works and something like in-depth interface troubleshooting would be a good topic for it.
This sounds like unexpected behavior to me. Have you brought this up to support?
