Quad Cortex Tap Menu, make It go away?
Hi! When I press “Tap” on my Quad Cortex, this menu pops up briefly and then disappears. Is there a way to disable that? I’m using “Stomp Mode” and would like the “pedal menu” to stay visible even when I press Tap.
Is this possible?
no way to disable presently, but if you tap any other switch it will close.
vote here: Tap Tempo Screen Update
