hello guys.
I bought the QC mini & my cioks dc7 with extra cables I used for my big Qc version..
how do I connect the cables, the same like the big QC or different?
hello guys.
If you switched from the larger QC to a Mini, just use the cables the same way by paralleling the outputs.
The Mini uses less current–it averages about 1A–so I would recommend using three outputs in parallel. This way you’re not running your outputs at max (500 mA each).
oke i see. so I need a buy a damn new cable for that 1 output or?..
because I have all those original cables from cioks itself.. but I don’t know if that’s the good one..
Or can i just use it like in the photo? Just pulled 1 out.. but dont know if it could do some damage to my QC or cioks?
I think just use one less. Connect one to outputs 4 and 5; connect a second to output 6 and the free end of the prior connector. Then the QC into the free end of the second connector.
Just parallel three of the outputs instead of four. No need to buy new cables.
You’re probably better off getting a blessed cable rather than a dawned one. Unless youre evil.
Also remember to adjust the voltages on each power outlet on the DC7 for the QC
