Describe your issue: This issue is with QC mini when using the looper in stomp mode. If the looper is assigned to a stomp footswitch on page 2 holding B to get to page 2 also controls the looper and changes it to page 2. So when you press the footswitch to open the looper it’s now on page 2 and not the main record page that you would want to start on. You then have to hold B again to get to the main recording page. Then exiting the looper you would assume you’d still be on stomp mode page 2 but when you swapped the looper to page 1 with the looper open it also switches the stomp mode page. This is annoying when trying to loop on the fly. Changing pages in stomp mode needs to be disconnected from the looper hold functions. The looper pages only need to change when the looper is open. The page changes when the looper is open doesn’t need to change the page in stomp mode. Thanks.
Not fixed in the update. This is pretty annoying. Please fix asap. ![]()
