QC Seamless switching in combination with a real setlist/song feature
Does the pause when switching patches get on your nerves? Yes, I know you can work with scenes, but then you have to build a thousand functions into a preset, which just makes it cumbersome. The Nanocortex shows how cool it is to just be able to work with presets.
Can’t you just build it so that only two cores (the top two rows) are used? This would make it possible to preload the next preset into the other two cores.
In order for the QC to know which preset should be recalled or preloaded next, you would have to modernize the QC’s grotty setlist construct at the same time. The implementation of the VST host Gig Performer could be used as a guide here. There, presets and setlists are completely separate. You build each of your songs in such a way that you tell the tool which parts it consists of. Each part can then be assigned corresponding presets, midi commands and the like. If something needs to be changed in a preset in a song part, a scene attached to the song part can record the changes to the patch. Any setlists can then be created from the songs.
The QC would then finally be 100% user-friendly, not only in sound creation but also in live operation. The dear effect device programmers like to lose sight of live operation because it is more important to program the 200th echo.
I bloody hate it…
Don’t know how these guys from Gig Performer have done it but it is true… Zero latency when changing presets!
I suspect that you have significantly more computing power available on a real computer. With my i9 notebook, I have no problems running three or four NDSP plug-ins in parallel and playing a lot of synthesizer VSTs with Guitar2Midi3 at the same time. In addition, the setlist/song function gives Gig Performer a better chance of seeing what’s going to happen next.
I think they use some special method for patch changes. It’s rock solid on my 2015 macbook.
