QC Mini Outputs and G3 Atom
Hi all,
I currently run a wet dry rig from my G3 Atom, and have just bought a QC Mini.
I am wanting to have the option to send the dry effects to 1 loop in the G3 Atom and then have the option to send the wet effects to another loop, or both if possible.
I was thinking if I go to the input of QC Mini from the Send of Loop 5, and then take the output 3 from the QC to the return.
Then just take an output from QC Output4 to the return of loop 6 then i can then select the outputs and activate the loops on the g3 for the presets?
Can anyone advise if this is possible.
You should be able to route this with the QC mini. Just make sure you select the correct stuff in the chain of your QC mini preset. But that’s a pretty simple thing.
Did this work for you? I found that the signal dropped significantly when I connected the QC mini in front of my amp for any reason, be it 4 cable method or just as an individual channel
