Qc mini and real amp
Hi there,
Just getting started with my QC mini. I’m trying to have the quad cortex do two things be my wet effects pathway, with the main input coming from a signal splitter from my pedalboard, the other signal goes to the amp input. In one of the pedals of my pedalboard controller I have a separate loop going into the input 2 of qc mini, and then to out 3 to go in front of amp, the only purpose is to hae some pedals from qc mini going into the front of the amp, however when I activate the loop with the qc mini in front of the amp, I have a significant volume drop even after increasing input gain, and the output clipping, there’s just a very noticeable drop in volume/gain
Any suggestions howto fix?
UPDATE so I reached out to Neural and one of their recommendations was to connect it with four cable method. I did that but still experience significant drop in volume despite having what looks like a correct setup, you can see the set up in video:
