QC Lockup and in Reboot Loop After Downloading Some Presets
CorOS Version: 1.3.4 (updated when I received the unit today0
Describe your issue:
I got my QC as a Demo from Sweetwater, which probably means it has been returned by a customer. My QC is locking up after downloading some presets. It gets into a reboot loop and there is no sound and I can’t change presets. I have already done a factory reset and it functions fine on factory loaded presets. I have sent a diagnostic log to tech support. An error message pops up that says:
"Something went wrong
Your Quad Cortex experienced an unexpected problem. If you continue to experience this, please send a crash report to us to diagnose the issue.
I sent a crash report after the first lockup AND after I did a factory reset and it did it again. Has anyone else seen this issue?
  1. Download and install shared presets
  2. It seems to be presets that are more complex that causes the issue, such as those that have a higher CPU usage or use both inputs 1 & 2
  3. I’ve done a factory reset once and it has locked up again from a preset by Rabea.
I expected this to happen:
Loading any downloaded preset should function fine.
  • I did a factory reset once.
  • I added simple presets and seems to be OK
Hi @RockingCPA, Sorry to hear you are experiencing issues with your QC locking up. Since this is not normal behavior, please reach out to NDSP support@neuraldsp.com and they will get your sorted quickly.
Email sent. It seems to be OK with factory presets or slightly modded factory presents. A preset from The Studio Rats is fine, but that is just a slightly tweaked Brit 2203. The Icles from RabeaAfro crashed it and some from a buddy that are using 50% + CPU with multiple inputs did, as well. Once it has crashed, rebooting doesn’t seem to immediately fix it. Pure speculation on my part, but it seems like something a computer would do when the RAM or CPU is not working properly.
I need to set up a preset with scenes with an acoustic emulator, AC30ish, crunchy Marshall and a boosted solo setting. I like to go from left to right across the bottom from clean to solo with a different version of the same scene above on A thru D. I’m going to start adding blocks with a 2nd amp and cab for an acoustic IR. Let’s see what happens when I start to push the CPU with 2 amps, 2 cabs and some time-based EFX. I’m coming from a Kemper Stage. I like the sound of the QC, added CPU power, and interface, but having a computer-based system lock up on you is pretty scary to use in a live gig situation. ZERO problems with the Kemper in almost 3 years and probably 150-200 gigs. Fingers crossed that the QC can be this reliable, sound better and be more compact for travel dates.
Well, I updated to the most recent firmware 1.4 that came out this morning, hoping that it would fix the problem. NOPE!! Now, I have no sound at all and the reboot loop is constant even with factory presets. Very disappointing.
@RockingCPA - I checked in with support and it looks like we only have a report from you but no email. Please email support@neuraldsp.com so the team can look into this.
If you already sent an email please dm the email you used to send it with so I can confirm we received it.
Thanks!
