I’m having some issues with having a wah block in my scenes. looking to see if anyone has managed to get it to work correctly.
Current setup
QC to Hotone Ampero Press II with TRS connected to QC’s Expression 1 & 2
The wah is working perfectly fine however the problem is when i change presets and switch back to the mentioned preset, the wah is always turned on with toe down by default even though i have saved the preset as wah off by default.
Hey there, i am struggeling with this problem, too.
I got a simple M-Audio EXP and it works very well after choosing the Assigns (heel-toe or stop).
For some strange reason, now it will stay off when changing scenes (in the past it was the same you told) and works.
BUT:
…now, when i am changing the preset, it seems not to save the assignments.
Opening the same present again the pedal does not react.
In the Assignment-Menu everything is like i did.
When i chang a parameter it is back …
Maybe someone had the same issues…
UPDATE:
It is the BYPASS-Assign which gets lost by preset-change.
WAH still reacts…
Hi, in my case, this happens only when I use clyde wah (I mean, when I change clyde wah to something like bad horsie and save, the assignment stays as it is even when I change presets.)
I wanted to use clyde wah for the next gig, and I was totally at a loss, when I happened to find your comment about workaround, and it is working perfectly!
I really appreciate it!
I will report this bug to neural support so that this will be fixed in the next update.
The wah was on when I went back to a preset after saving with the wah off, same as the above posters. Maybe I copied a preset with the wrong settings; I think I did.
And the wrong setting was found by going back to “Assign Expression Pedal” in the context menu when you click on the wah to look at it’s settings. WAH and BYPASS were both “ASSIGNED”. Just click on “ASSIGNED” for the BYPASS to unassign it and then Save the settings. Then the wah pedal is not on when going to a preset unless you Saved with it ON.
