I was having the above problem, Mission Engineering told me change the switch inside the 529 from 2A to 3A and everything worked fine.
Hello,
How did it go with the 529? hours of charge, use, amperage etc.
How did you change the switch inside? I found no documentation on the mission engineering site
When I open den 529, there is a switch with 3 a but is has 3 positions and just 3a and 2a written above. Do I need the set it all the way left or in the middle?
