Anyway to get the delay to repeat into oscillation
Like on the Boss space echo? With an expression pedal somehow?
Just set the expression pedal to go from (heel) normal feedback, to (toe) 100% feedback.
You can also do it with a momentary foot switch.
You might want slightly less than 100%, depending how extreme you want the oscillation. You can also assign other parameters like modulation and tape warble etc, or even the high/low pass to get a “nicer” feedback.
