I don’t know enough about electrical hardware, so my question is:
Is it absolutely necessary (if everything has been saved manually) to shut down the QC regularly using the power button? Or can I simply switch off the power supply at the power adapter?
Thanks in advance
It is safe to just pull the plug. NDSP has confirmed this multiple times as well.
Either way is fine.
thank you both for the quick clarification!
