Power locking functions screen keeps coming on
CorOS Version: 1.x
3.0
Describe your issue:
When I do x, y happens
The power locking screen randomly pops up and keeps coming up . Will go away when I reboot but not always. Why is this?
I have been in touch with support and sent a screen shot but no fix as of yet if this is an actual issue.
Thanks in advance for any help.
  1. Step 1
  2. Step 2
  3. Step 3
I expected this to happen:
When I do x, I expect y to happen
  • I have tried x
  • I have tried y
  • I have tried z
There was another issue reported with the power locking after the 3.0 CoreOS update where just the sound came on spontaneously. This could be related but perhaps not. Try going to ‘Settings’ → ‘Device Options’ → ‘Power Button Sensitivity’ and decreasing the sensitivity setting.
Thanks I did that.
This issue was going on from several updates back though. Was hoping the new update solved it,
Thanks
https://www.bandsintown.com/es/a/6936820-jim-robitaille
https://www.amazon.com/Sound-Origins-Developing-Musical-Identity/dp/0692492437
http://www.daddario.com/DADMobileArtistDetail.Page?ActiveID=3835&ArtistId=43034
https://m.youtube.com/user/JimRobitailleMusic
http://www.umassd.edu/directory/jrobitaille/
I just got mine couple days ago, I’m having same issue, the only way to fix it, is to turn off power button function, so now I’m supposed to turn off the qc by unplugging the power supply ?? called Sweetwater to see what can be done, did the reset factory still have the same issue .. any help appreciated
Any solution to this?
Hey There. I have the same issue with my quad cortex. I just bought it from someone. When we tested it at their home everything was working fine. Came home plugged it in and I think after I did a factory reset the button seemed to be activating continuously. I get the power locking options. That keeps popping up even if the sensitivity is set to medium.
I tried cleaning the area around the button, factory reset, reset all settings and the issue continues unless I turn off button sensitivity completely
Did you find a solution?? Thanks !
