When I use the plugin, I only use the compressor and distortion pedal. I shut off the amp, cab and everything else, because I’m using my Axe fx for many of those components. With the Plini overdrive pedal, there are unsual bassy artifacts when you are playing,…it muddies up the sound so much , the distortion is unusable. I keep the drive at super low and the level at around 12 oclock, and after playing some, the artifacts will come in. This isn’t from a low latency setting…it’s something within the overdrive.
Has anyone else noticed this?
