Playlist Editing
The facility to build playlists is great but suffers from a wee problem or lack of functionality. Once you have created a playlist it is impossible to do anything other than add to it or delete from it. It is very annoying not being able to insert a preset into the list and have everything else shuufle up a slot or when you delete ahve everything shuffle down a slot. The problem here is if you make a mistake in the oreder or miss out a preset in your running order you have to create the playlist again from the position of the mistake. Or indeed if wish to slot in a new preset into your playlist the same problem exists.
Can you consider this funcionality when you look to send out corOS 1.5
Thanks
Robbie
I think this will be resolved in 2.0 which is hopefully up next
Yup. Need this!
