Hi i have downloades pilini trial in pt10 hd, 32 bit. The plug in works perfect in standalone but when i open it in pro tools and press record it bypasses the plugin.
the plugin will however work over a pre recorded track
some help would be great
Make sure to enable both Record and Monitoring. Also, disable Low Latency Mode (Options > Low Latency Monitoring).
Thanks but its pt 10 hd that feature is in 10.
it Seems the plugin will not play nice in a 32 bit system also started throwing up 9128 messages which my system never does. i have managed a work around in the standalone mode so all good
