Hi @Gonzalo, I ran the test using Latencymon. Here’s the full report:
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:00:47 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: WIN-P9IVHLOHBVM
OS version: Windows 10, 10.0, version 1909, build: 18363 (x64)
Hardware: 20N4CTO1WW, LENOVO
CPU: GenuineIntel Intel® Core™ i7-8565U CPU @ 1.80GHz
Logical processors: 8
Processor groups: 1
RAM: 24323 MB total
CPU SPEED
Reported CPU speed: 1992 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 153.60
Average measured interrupt to process latency (µs): 4.895123
Highest measured interrupt to DPC latency (µs): 147.10
Average measured interrupt to DPC latency (µs): 1.445860
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 115.189257
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.020015
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.020365
ISR count (execution time <250 µs): 20500
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 4437.036647
Driver with highest DPC routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total DPC routine time (%): 0.218970
Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 0.268837
DPC count (execution time <250 µs): 146705
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 6
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 1
DPC count (execution time >=4000 µs): 1
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: explorer.exe
Total number of hard pagefaults 57
Hard pagefault count of hardest hit process: 42
Number of processes hit: 6
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2.797447
CPU 0 ISR highest execution time (µs): 115.189257
CPU 0 ISR total execution time (s): 0.076450
CPU 0 ISR count: 20399
CPU 0 DPC highest execution time (µs): 4437.036647
CPU 0 DPC total execution time (s): 1.001375
CPU 0 DPC count: 145768
CPU 1 Interrupt cycle time (s): 2.897110
CPU 1 ISR highest execution time (µs): 22.325301
CPU 1 ISR total execution time (s): 0.000173
CPU 1 ISR count: 101
CPU 1 DPC highest execution time (µs): 169.680723
CPU 1 DPC total execution time (s): 0.005408
CPU 1 DPC count: 248
CPU 2 Interrupt cycle time (s): 1.365486
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 65.960341
CPU 2 DPC total execution time (s): 0.001264
CPU 2 DPC count: 161
CPU 3 Interrupt cycle time (s): 1.352966
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 72.386044
CPU 3 DPC total execution time (s): 0.000226
CPU 3 DPC count: 24
CPU 4 Interrupt cycle time (s): 0.862581
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 18.3750
CPU 4 DPC total execution time (s): 0.000318
CPU 4 DPC count: 59
CPU 5 Interrupt cycle time (s): 1.225214
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 47.730924
CPU 5 DPC total execution time (s): 0.000085
CPU 5 DPC count: 9
CPU 6 Interrupt cycle time (s): 2.358832
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 34.818273
CPU 6 DPC total execution time (s): 0.002287
CPU 6 DPC count: 367
CPU 7 Interrupt cycle time (s): 1.990758
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 63.466365
CPU 7 DPC total execution time (s): 0.000530
CPU 7 DPC count: 77
