Petrucci | MIDI Sweeping parameters on Behringer FCB1010
Hi, guys!
I’ve been trying to use the Behringer FCB1010’s expression pedals to control volume and wah individually.
The trouble is I have the pedalboard set up correctly but I can’t seem to use expression pedal A to control sweeping for volume. I can only use expression pedal B for that. Expression pedal A only toggles the volume pedal from 0 to max volume immediately.
Has anyone had this problem and found a solution?
Thanks!
I had this same issue and had to go into the settings of the FCB1010 and change the say max (127) to a setting that would only reflect my max amp volume of say 60% or 1 o’clock.
