When going from footswitch I to II. It will go back to previous selection on the other switch.
Eg. Say you have your presets set to IA and IIB. You go from IA to IIB no problem. But if you were to go back to IA but then wanted to go directly to IIA you can’t. It would go to IIB because that’s where you left off.
Would be nice if you could hold switch II (which would go to IIB right away per the above scenario) and it would silently cycle to IIA after say a 1 sec hold.
If you wanted to go back to IIB keep holding another second and it would go to B (say you changed your mind).
Hopefully that makes sense. Poor man’s workaround to directly be able to select any 4 presets with just 2 switches. Otherwise without 4 switches, you basically stuck to only directly accessing 2 presets.
