Pedal Expression Whammy Problem
Good afternoon!
I have a problem with the M-Audio EXP Expression Pedal through the M-Vave Chocolate Plus MIDI controller. I bought the Archetype Gojira X plugin and when using the whammy effect it works incorrectly, changes the tuning abruptly, not smoothly. This same pedal with this controller works fine with the first version of Archetype Gojira. I assigned the pedal midi channel 1, CC11 from 0 to 127 and it works without problems with other plugins, I tried the learning mode, but it didn’t help. I installed the demo version of Archetype Tom Morello X and there is the same problem with whammy. Tell me how to solve the problem.
Hi. I have the same problem, in the first version of the plugin there are no sudden jumps from the bottom position to the top position and back again. This is very frustrating, as I bought the plugin only because of this feature, with a smooth transition when switching pedal position. If you find a solution to the problem, please post here.
Give NDSP support a try, email support@neuraldsp.com and they will get you sorted.
Thank you! I wrote to them, no response yet.
Yes. If I had known this in advance, I wouldn’t have bought the X version of Godjira. Now there’s no need for problems.
Upd 19.05.2025. I found a solution to this problem Doremidi MPC-10! Maybe someone will be interested. Thank you all for your attention!
