parametric EQ changes not responding when assigned to scenes
CorOS Version: 4.0.1
Describe your issue:
When I assign one of the parametric eq nodes to turn on on a certain scene, and turn off on a different scene, changing scenes does not actually affect the node’s activation status.
  1. Assign one of the 9 parametric EQ nodes on/off setting to scenes.
  2. Assign it to the on state in Scene A,
  3. Assign it to the off state in Scene B
  4. Notice how changing between the scenes does not affect whether that EQ node is on or off.
I expected this to happen:
What should happen, is the node should deactivate and activate as assigned to the particular scenes, as they are recalled.
  • making sure I am assigning the correct parameter to scenes
  • assigning to different scenes, problem still persists
I checked this out with my QC (same CorOS version) and I don’t have this problem. Individual channels within the parametric EQ block respond to Scene changes just fine.
I am not able to duplicate this issue either. Check your main settings for scene behavior, otherwise
feel free to email support@neuraldsp.com if you continue to have this issue and they will get you sorted quickly.
