Graphical error when setting the Parametric 8 EQ output value by scenes
CorOS Version: 4.1.0
Describe your issue:
When I set the “Output” parameter of the 8-band Parametric EQ to vary by scene, a purely visual error prevents the value set for each scene from being displayed, even though the audio itself changes. I don’t know if it happens for the other EQs
  1. Step 1
    create a rig with Parametric 8 EQ
  2. Step 2
    setup 2 or more scenes
  3. Step 3
    set a different value for the Output parameter for each scene.
  4. Step 4
    While remaining on the EQ screen showing the Output parameter, click the footswitches to change scenes.
  5. Step 5
    Audibly, you can hear the settings for the Output parameter changing. Visually, however, the value does not change; it only updates if you subsequently turn the footswitch to change the value again for the current scene.
I expected this to happen:
I expect to see the Output parameter showing the value corresponding to the current scene.
I tried exiting the EQ screen, closing the panel, changing the scene, and reopening the EQ panel and I see the parameter correctly reflecting the selected scene.
