Hi,
As the QC does not record/save the sounds created in its looper, I have the Nux Looper which does save the sounds.
Hence I would like to use the Nux but not sure how to set it up.
Please advise.
Thanks
I have the Same and use it in an FX-Loop at the end of the Signal chain. You can is the footswitches to send midi commands to the Loop Core, too
Thank you for that.
How have you set it up?
As stereo?
Being new to this I am not sure where I plug the cables in and , how do you set up the Nux on QC.
Sorry for being so incompetent but it seems simple but, I’ve confused myself on this.
Thanks
It depends, if you have other effects in an effects loop, the only option is mono, If you want it in an effects loop and the qc as main output device. Normal effects effects loop one, looper effects loop 2, but it’s mono.
For Stereo and Qc as main output device:
Just put an effects send 1+2 and a return 1+2 at the end of the signal chain and connect the cables the same.
Effects and Looper stereo but output through looper:
If you keep it after the QC you can use output 3 + 4 to go to the Looper and Connect headphones or Speakers directly to the Looper.
I hope this helps
Hi,
That’s excellent
Thank you very much.
I will try it a bit later.
Almost there with what I want to do.
Again.
Thank you
