Hi. I am using the QC outputs to feed my ditto x2 looper in mono. It’s the only looper I trust to stay in sync with my beatbuddy drum pedal. That is until QC addresses the almost 2 year old issue of midi clock sync in the QC looper.Can I put the ditto on send return and then use the xlr output or stereo out from the QC? Thanks!
Yep. I do this currently.
Ditto X2 in loop 2, placed on the grid between amp and IR blocks.
The second output of the Ditto doubles as a send to my onstage amp/cab, while the XLRs remain set up for FOH DI signal.
Actually I have the ditto jam x2, which is mono. But yes, I will place it on the loop after the cab and I should be ok. Thanks!
I’m a noob. how do I do this? I am using a ehx95000
At the end of your chain, add send1-return1. Connect send 1 and return 1 from the back of your cortex to in/out of your looper. That’s it
