Noisegate issue in 2.0 update
The noisegate in my main rhythm sound has moved to the input block and seems to be turned on. However, when I switched to a different preset and then back, I can hear that the noisegate isn’t working anymore. According to the app, it is still on. If I turn the noisegate off and on again, it works. But as soon as I switch between sounds, it’s not working again.
I tried changing the noisegate level and saving the preset again, but that makes no difference. For now, I had to add a noisegate block again to make it work, but that’s not how it should be.
I am having the same issue. I emailed Neural about it. Hopefully they will have an answer. Did you ever get it resolved?
It sounds like a bug. I unfortunately can’t duplicate this issue but reaching out to support is the best process to get it resolved. They will log your issue and review diagnostic then hopefully provide resolution.
I have the same problem with my NC…
