Noise when starting
Hi. Each time I start up my unit, this happens. Is this normal? Everything else works fine.
https://www.youtube.com/watch?v=qTxx91V6AGs
Definitely does not sound normal. I would start by unplugging everything and start by scratch until you determine where the interference is coming from. You may need to email support@neuraldsp.com so that they can log the issue and hopefully provide resolution. You could always try backing up locally or to the cloud, performing a factory reset then restore etc. Lastly please ensure you are on the latest (CoreOS 2.3.0) firmware etc.
I performed a factory reset, and now everything is working perfectly. Thanks!
Thanks for the update!
