Background hiss while playing
Hi guys,
since today, there`s some strange background noise (hiss) coming out of the QC while playing.
I had that once befor (unfort. during gig) but it was gone the other day. Now it´s back again… :frowning:
I tried to capture that in this video: https://youtu.be/Xr4IGFyele4
This noise coming through all outputs and those following steps didn´t help:
  • change power-options (incl power conditioner)
  • change cable(s)
  • remove all other devices from the signal chain
  • did a factory reset
“Fun” fact: The noise is getting less when the volume knob is on “100” - but still there. It´s louder between 0-99 (volume-level).
Any ideas how to solve that?
Thx a lot in advance for your help and all the best from Germany
Heiko
Pleaae contact support@neuraldsp.com
I hear the springs of your guitar…
It’s more like the speaker it’s near a snare drum :rofl:
Played it with a Les Paul - so no springs at all :wink:
But I agree, this is how it sounds like :see_no_evil:
Update (in case someone else has a similar issue):
I reached out to the support, sent a report and it seems (quote) “as if a cable that transfers the analogue to digital signal may be malfunctioning”
QC is now on its was from Germany to Finland (fingers crossed :wink: ) to get that fixed by Neural DSP.
Hey man @heiko
How your story ended ?
I have the same problem… i wrote to the support and i am waiting for their return…
2 days ago I noticed that my sound was crackling when I was playing. When I stopped, it was completely silent. As soon as I hit a note, there’s a hissing noise. I’ve plugged my out into both my P.A. and my poweramp+cab and both give the same results. I’ve tried different guitars, different cables and once again, hise noise. My Quad Cortex is currently powered by a Cioks Dc7 and the Cioks Crux.
My input gain doesn’t go any higher than -17db and my out level doesn’t go any higher than -12db. I use the stock amp in quad. The ground lift is off (i tried it at on and off and no change). It’s bad.
Hi Louis!
The QC worked totally fine after it returned from Finland. :blush::+1:t3:
No issues anymore…
Fingers crossed for yours!
Cheers, Heiko
@heiko hey man ! I contacted the support… thay answer me after 1 month lol… did you have to pay the shipping to sent your unit ?
Thank you !
Ahh yes, my unit is still under warranty !
Hi Louis!
First of all: Sry for my delayed answer! I´m not that often in this forum! :see_no_evil:
Support sent me a return-label so I didn´t have to pay the shipping.
As said - everything went quite smoothly!
Fingers crossed for you!
Cheers, Heiko
