Got a feeling it’s an easy fix (I just got this awesome unit) and I’ll continue w the manual and tutorials… but:
I downloaded Martin Miller’s 8 presets. No problem. But when I try playing there’s no sound. I notice there isn’t an amp or a cab…but even when I add one: still a no go.
Look at your signal chain, if a preset is using XLR outs 1 & 2 and you are using outs 3 & 4 etc., you won’t hear sound (excluding headphones), same if you are using outs 3 & 4 and the preset is configure to use XLR outs etc., you need to check the inputs and outputs of the presets.
Started on the manual last night. Starting from the top to begin with. Appreciate the tip. I’ll check it out when I get home. Tanks fer da tip!
I did notice that there isn’t m an amp or cab in any of his presets. Is that by design? Up to the user to find one they like or use their own physical rig?
Looking at Martin Millers presets, some use cab blocks and some don’t. If you don’t see a cab block used, that most likely means he is using a preset with a capture of an amp/cab baked into the capture. Sometimes, the details will specify or the name used for the capture might indicate a cab/mic are baked into the captures.
