No LEVEL control via Expression Pedal?
According to the latest manual we SHOULD be able to control the level via an Expression Pedal. Is it something I’m missing?
PARAMETER RANGE
GAIN, BASS, MID, TREBLE, AMOUNT, and LEVEL knobs.
1 Tap the parameters you want to control via the expression pedal.
Multiple parameters can be assigned at the same time.
Blah, blah blah
I use neural capture volume for level control.
Hi everyone I recently discover this… I must say that it is a bit complicated to use the volume control with the neural capture because is going for -24 dB to +12dB my neural captures are normally close to 0 dB otherwise are clipping. If there is no oher option I will open a feture request for this topic, it will be really usefull to choose between input level or output level but avoiding to modify the neural capture Volume
You can set max and mini for the total excursion of the pedal.
ah … I see what your’e missing! It’s Blah, blah, blah rtfm. :wink:
Thanks! That’s a pretty astute reply and some GREAT constructive criticism! I DID read the f’n manual…what I posted was directly FROM the manual! I even contacted Neural support and THEY said there is no Level control via the expression pedal. :wink:
Yep there’s just the volume fx block in the Pre Fx slot. Obviously that’ll alter the sound as you drop the volume but it’s all there is.
I need POST amp volume control. This is SO bad!
Yeah, We need post volume control. They should add it. In the meantime, I´m doing the trick controlling the level parameter of an EQ block in post. But that´s not the way it should be.
[quote=“andre.bellieny, post:1, topic:19829, full:true”]
Manual says we can control level with exp pedal but this option is not available. Can you include this?
[/quote]
I’ve made this request some time ago.
