I greet all. I have a problem and a request at the same time.
I have created one RIG and one side (OUT4) is not playing in it.
I wrote everything about the given problem on my website - guitar school (there are also photos) on this page:
Prosím poraďte, mám takýto rig (viď obrázok nižšie) a nehrá v ňom jedna strana rigu Please advise, I have such a rig (see picture below) and one side of the rig does not play in it Myslel som si, že je problém v nastavení spliteru, ale nie (teda...
Pozdravujem všetkých. Mám problém a zároveň prosbu.
Mám vytvorený jeden RIG a nehrá mi v ňom jedna strana (OUT4).
Všetko som o danom probléme napísal na mojom webe - gitarovej škole (sú tam aj fotky) na tejto stránke:
Set the balance to 5, not 10
Jamsden, Even if I set 5 (even if 1 it still plays only in one side and nothing plays in OUT4.
Aj ked nastavím 5 (aj ked 1 stále to hrá len v jednej strane a v OUT4 nič nehrá.
xush
March 12, 2023, 10:43pm
4
Can you upload that preset to the cloud so we can dig into it? Can’t see enough settings to deduce where it’s going wrong
MP_Mod
March 13, 2023, 12:52pm
5
I agree with the other please, please share your preset as not enough details can be determined from your post above. The other option is to email support@neuraldsp.com and they can work with you to resolution. IMO, it is likely a splitter/mixer not configured correctly but almost impossible to determine without seeing the preset.
Hi @marianguitar !
I think the problem is that your “multi out” is panned hard left.
Long press “multi out” to see the settings.
If you pan center, you get a signal on out 4 as well.
Yes, it was like that, thanks for the help and advice
