I’m using a UsB c Hub to connect the NC as an audio interface to an iPad (M1) Pro and Logic Pro 2 DAW. The buffer is set to 256 and there are clicks, pops and drop outs. It doesn’t seem to matter if I set the NC to record DI or FX stereo ( as the NC manual says to do). It is marginally better if I just connect NC direct through the suplied USB C cable but still causes issues. Any advice is greatly appreciated. Better USB C Cable? Higher Quality USB C hub? Anyone else experienced this problem?
SOLVED. Problem was due to trying to run a wifi enabled pointing device connected to the USB C hub through a dongle. Switched to BT only pointing device and no un-desirable noise!
