Mobile Studio question
I’m building a mobile iPad studio for use with Logic Pro 2 . I had some success connecting NC to Logic and recorded an audio track. Levels are set quite high but the playback of the recorded track is very low. Connections are as follows: Guitar to NC input, USB C to hub the to iPad (also via usb c). HP connect on NC outlet. Is there something I’m missing here?
Did you select the right input channels in logic.
You have to select input 3&4 to get the amp sound.
1&2 are the di signal from the two inputs
I will try that. Thanks
