I intend on also using the Nano as an audio interface. I play keyboard in addition to guitar and use a live DAW to control virtual instruments. That works great.
I also use a VST for guitar to MIDI conversion to control virtual instruments. Currently unless I use the Tuner to mute the Nano guitar I get the bleed through. I created a preset with low gain which minimizes the guitar coming through. Does anyone have a suggestion on how to bring down the guitar and keeping the level up? Is there a way to use a very low volume capture?
Yes, this is exactly what I meant in my FR. According to Support, there is no way to bring the volume down for Headphones. On Output L and R, if you lower the “Level”, the guitar will become quiet while sending DI and Processed signal via USB, but for Headphones there is no Option yet, as Headphones are not affected by the Level knob.
