When using the NC as an interface and direct monitoring of the nanocortex from the headphone outputs or outputs cannot be turned off. This way, if you are recording and want to hear your guitar in a mix (for example panned left or doubled), you will always hear the sound of the NC over all the audio.
Likewise, we cannot use real-time audio plugins, since in audio without plugins it will be constantly playing over it, which is very annoying. I, for example, like to process IRs from plugins after the NC with an amp head capture and hearing the raw amp over the mix is unbearable. I am currently connecting my output to an old interface to get the result I want, but it is highly inconvenient for me, since I have acquired the NC among other things to replace my old interface.
Giving the user the option to turn off monitoring would give a lot more flexibility in how the interface is used. I’ve seen other forum users complain about this, so I don’t think it’s a personal use case.
I have the same requirement. In fact sometimes I using the Neural plugins to get tone effects currently missing from the Nano.
As a workaround I have use a Nano preset with the capture and IR volume minimized. Not perfect but for live vst work it’s alright.
also this has been requested several times. it’s in the manual, turn on the tuner in muted mode and you’re good
Only issue is that the tuner also mutes the processed signal USB output. For DI that works great, I also mentioned that in my feature request for the exact same topic.
