More options between the FX blocks.
Such as a Comp/OD, phaser/flanger, Tape/Digital delay, Plate/Spring reverb.
I understand that the number of effects should be limited to allow gapless switching, but more effects could really help.
If adding more effects make gapless switching harder due to DSP limits, maybe you could allow to change the FX blocks for each bank at least, and change its parameters with the presets in the bank.
Yes, DSP has its own limits, but keeping the current number of slots (2 pre + 3 post) but with more types of effects in case the application will display DSP usage, we can decide which effect and how many effects we can use to not exceed the limit (e.g. 80% DSP).
I absolutely agree with you, especially the lack of Comp is a big problem.
And I would add: per preset.
Maybe you need the transpose function just for one preset in an entire gig, and then you put another effect (comp, od…) instead for other presets.
That would make the unit an all-in-one for the huge majority of use cases.
Of course, per preset ![]()
