Effect options for each slot
Possibly a minority on here. I am considering the Nano almost purely for the simple capture process to act as a back up & practice version of my modded Princeton Reverb which I use at all my gigs. However, it does have 2 pre and 3 post FX slots but I’m put off by the current options. I have no use for a noise gate or pitch shifter so it would be great if those could be swapped for a comp & drive (Preferably with dry blend). The post Effects look fine. A Spring verb option would be nice. Tremolo option in the chorus block (although, that is a good choice of chorus). A tape delay option. The simplicity & size of the unit looks ideal. These options would make it a no brainer
It would be nice for sure. The transpose feature isn’t very good for anything other than heavily distorted tones anyway so I team mine up with a digitech drop. There are some captures with a boost baked in if you look for them on the cloud although that isn’t ideal. The drive control on the unit is good though so you could for example set one slot as the normal capture and another with the drive turned up. That’s what I do and it works well.
True. My plan would be to make captures with my drives as well. Having access to another drive that I don’t own would still be more useful than pitch shift. That seems a very genre specific choice. But yes. In some ways it would be best to occupy all the slots with time dependent fx that can’t be captured. I know from making 100’s of Kemper profiles that Compressors don’t capture successfully so that would definitely be an improvement. It could have noise gate built in. Wah would also be useful in a pre slot
Another option that I think fits this request is that the chorus block should allow for any sort of modulation… flanger, phaser, tremolo, vibrato, etc not just chorus.
Well, my other topic “Option to put stomp/drive captures into pre fx slot” was locked by the moderator saying that feature request was similar.
I had said “If I capture one of my drive pedals, I would like to be able to put it inside the pre fx slot like the other drive pedals.” and this was not the request under this topic. Not even close. They are talking about capturing drive pedals with the amp. However, I was suggesting something more flexible.
I was suggesting another capture category for drive pedals only and being able to use them in pre-fx. This is not similar to what is being said here. So please unlock my other topic so people can respond.
Agree with you!
I think this request has, in fact, been solved in NanOS 2.0.
Sure there’s no tremolo or spring reverb yet, but the core of the request is more flexibility in fx slots with an emphasis on drives and comps and that exists now.
And I agree that yavuz’s request is different (essentially asking for a second capture slot).
Actually, I was hoping for a different category for capture that could fit in pre-fx.
In other words maybe a privileged capture :slight_smile:
