I have the Mission Exp Pedal with two connections possible. It’s pretty easy to figure out how to control 2 parameters within the same block; but can you use one connection to control a parameter on one block, and perhaps hit the toe switch to control a parameter on another block?
Since the switch is an on/off toggle, all you can really use it for is assigning it to bypass to turn an effect on and off. Not really usable for other settings or parameters.
You can invert the bypass setting of 2 fx blocks and toggle between them with the switch, that may be more what you’re asking?
Are you aware that the Mission exp pedal made for Neural has 2 cable connections (from pedal to both exp 1 and exp 2)?
Yes, I have and use that pedal. The second connection is for the toe-switch only, it will not send pedal-sweep information.
I guess I’m not exactly sure what you’re asking in the original post
